DK Custom Comfort Lift™ Kit
Jun 15, 2013
9,117
8,814
Red Banks, MS
DK CUSTOM PRODUCTS
Comfort Lift™ Kit
See more photo's & Specs HERE
http://www.dkcustomproducts.com/Harley-Trike-Lift-Kits_c56.htm
No wobble with mine, I change up the pressure quite often. Big improvement with steering. This is the Best add-on mod I've done, very happy with it. ThumbUp
DK CUSTOM PRODUCTS
Comfort Lift™ Kit
See more
wheQUOTE]​
When the lift kit is installed if you were to pump up
the air shocks to max would you feel some 'side to side'
play or wobble when traveling straight down the road?
The lift kit does not increase or decrease any side to side movement. If you have it now, you will probably still have it afterwards....side to side movement is a function of one, or a combination of the following-
1. Poor quality factory shocks
2. Worn Swingarm bushings
3. Worn panhard rod heim joints
If it is just the wallowing from the factory shocks you are experiencing, it is possible that with the install of the Comfort Lift™ AND pumping the shocks up to the max, it may wallow a bit less.
Check out our Report on rear suspension at this LINK, you may find some of the information useful.
Similar threads
Flyboy7312
