I second the Contigo.
My my main requirement for a drink container is to close securely without a lot of effort. It avoids your drink splattering all over you and your trike.
The Contigo 20 oz. Snapseal is like a childis "sippy cup". You can close it and turn it upside down with a carbonated drink and it will not leak and it keeps drinks cold almost as well as a Yeti.
The slightly flared top allows ot to perfectly fit a Kuryakyn drink holder & it's center of gravity is so low that it will not accidently tip over. ( mounted on Valk )
Note that the Kury drink holder can be locked in place or allowed to sway. If you want to let it swing back & forth, you should use blue loctite on the locking screw.
The kury holder comes with a nice insulated stainless cup about the right size for coffee.
However, hit a strong bump and the contents will spray back at you unless you close the opening AND point the opening at about 11:00 o'clock.
Dan
Dan
