The answer is yes and no. Obviously all trike conversions use an entirely different gearset, which is an automotive based ring and pinion differential drive setup. The final drive gear set ratio as well as the wheel and tire size is based on each manufacturer's testing as to what gear ratio is needed to propel the trike at as close as possible to the the same RPM range and performance as the stock 2 wheel bike. Technically, it may not be the exact same gear ratio, but will result in the best setup for that bike.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
