CSC Trike kit tail light.
Aug 17, 2021
3
13
Memphis
Good Morning,
Since this is the CSC Forum, just wanted to see if anyone knows where I can find a replacement tail light for my retired sport trike kit? I posted this on another forum, but the only lead I got was for Saber Cycle, but was not highly recommended. From what I understand I am needing The Saddlebag-corner-light-turn-signal-set-GL1500-AMBER. Here is a picture of mine and one of what I believe that I need. I just need the right side as it is cracked and has been glued back together.
If you don’t wanna buy new, try eBay. You should find lots of listings for left /right side Any yr from 1988 thru 2000 works. Keep in mind that if you want both sides to match perfectly you should buy new or confirm used items are removed from same wing. In some cases a good buffing can make both lenses match Good luck with your search. Enjoy your CSC Trike. Looks great :wave4:
mrnick1979
