Cooling fan
Re: Cooling fans.......heat kills...
Sucks having to plan rides around the weather
reports!
Believe me....as an MS patient, we know all too
well about the effects of heat....it'll put my aZZ in
the ER faster than you'd believe.
Sooo......your saying size matters?......;)...
AIR FLOW!......cfm would be the deciding factor
for me......I'm just sayin'........:Shrug:.....
But....I dunno......?...
Has anyone here installed the Ward fans themselves ?? Whats involved in this ??? Like mounting, wiring, getting power to them, any tips ? Thanks,
Sully, it is a simple "plug and play" installation! Goes on the horn bracket and the wiring just plugs in. Also, Ward provides very good and simple installation instructions with the Fans. I have them on my 2013 Trike with a 120r crate motor and the provide approximately a reduction in head temp by about 25 - 30 degrees.
Good luck, you will like them should you choose to install them. :pepper:
Roger
Sully, Like Roger said "simple" & Wards provided a bracket that allowed me to install with my mini breast horn, compared to the horn cover the fans blend right in & everything worked great. Jason, the designer & builder of the fans is very helpful & will try to answer any concerns or questions you may have.
I just swung by Jasons house and picked mine up. One bolt holds them on and two wires, I used the Acc connector under the seat.
Big Red,
Sorry your thread turned into such a fiasco. Let us know what you think of your Love Juggs fans.
Well after what i seen and the talk from all you guys about there bikes and fans. i ordered the love jugs.
2 to 3 times the air off them. size no big deal to me. i had fans that could not blow out a candle. so i will go with the jugs.
its going to be in the upper 90's
over the week end. And i going on a poker run so i will fine out for my shelf how they work. Thanks for all the in put from all of you
Big Red and Chris
dhinzman1
