Clutch Adjustment
Hey Guys,
I have a 2011 Harley trike and would like to know when to adjust the clutch. Two years ago I installed the Barnett #1 and the clutch wiz with the proper spring that Mr. Wizard recommended to me. Since then I have put over 7,000 miles and I don't really know if the clutch is fine or not. I don't find any problems with the trike when we ride two up and pulling a trailer. I guess if it aint broke don't fix it ??? Any suggestions and proper procedure to adjust would be very helpful.....Thanks to all who reply.
Hey Guys,
There is normal maintenance you should do, yes?
I have about 10k on my same set up as you and I haven't had to adjust the clutch. You are correct in saying that if it isn't broke... blah, blah..
Hope all is well.
-Wiz
mudrock
