Check Valve Required
Lawingnutz
Banned
Sep 12, 2014
35
13
Laplace, La, USA
Oh boy, I screwed up.......My Hannigan trike has the Aux fuel tank. The Aux fuel transfer pump transfer line had a check valve installed. When I changed to the Roadsmith fitting I removed the check valve. I saw it as just another failure point. Since the fuel was now going to be going straight into the top of the tank through a hole I drilled in the fuel level sending unit metal plate there was no need for the check valve, or so I thought. Well I learned that I was wrong. Fuel from the main tank is finding its way into the Aux tank and overfilling the Aux tank. The Aux tank vent/overfill tube is putting gas on the ground. This should explain my poor gas mileage. As soon as it warms up a bit I will reinstall the check valve.
Live and learn!!!
Live and learn!!!
I just hate it when I have to learn the hard way!
Hang in there. And put your cigarette out!!!
If you wanted to remove your check valve you would have to reroute your fuel line so it was higher than the main fuel tanks highest level, that would prevent a siphon. I wouldn't advise it but you could remove the check valve with the hose reroute.
Good luck and I hope it warms up soon.
Kept the check valve and will simply reinstall it, not a problem.
Dan2003
