Champion Solid Axle Third Member Identification.
Dec 2, 2024
5
2
Las Cruces, Mexico
Mike
I have a 2004 GL1800 with a Champion solid axel kit. I am needing to find out what model Toyota the diff third member was out of. The axels are four stud. I have looked everywhere for a similar looking third member, I even contacted Champion. The only information I can get is it is from a Toyota being the bolts on the drive shaft have nuts behind the Diff flange. I really need to find out what model Toyota this came from, so I can find a replacement. Note raised bolt in axel housing even with the drain plug, Totally round pumpkin with only small indentation at the fill plug and last the top rib is raised above the hump on the raised rectangle area: this feature I have not found in any on line photos I have look at.thumbnail (1).jpg489820577_690223533507569_8404866147004942808_n.jpg489928001_690223443507578_2115573642347110473_n.jpg
Unfortunately I'm even more clueless than you on being able to identify it. I'm kind of surprised we haven't had someone more knowledgeable drop in on this thread yet. Hopefully someone will soon.
The axles are probably custom to Champion.At least they are cut to length.I think I had it narrowed down when I had mine and for some reason 80s Supra comes to mind.I would contact someone like Yukon gear.I think most of the pics and info is truck oriented and they could easily be modified car axles.I can't imagine a 2.93 ratio came in many models.
Your welcome.It frustrates me that I can't seem to find those identification guides on the net anymore.Like the old wallcharts we used to have.Randy's and Yukon used to have them and maybe I just am not looking in the right places on their sites.
dyno56ca
