Champion Conversion Kit
Oct 6, 2024
56
25
FL
Pamm
I noticed on the wheel cap the name Champion. So mine must have a Champion Conversions kit. I had the guy that put my new tires on change the Grease/Fluid in the rear end and he said there was only one grease fitting under it he seen and it was on the drive shaft. Is there more I need to do to that half of the trike? Or is there a owners Manual on conversions?
This manual is for a Champion conversion on a GL1500 Goldwing.
TO: Trike Lady, Thank You so Much . I have read it all and see a lot now that makes sense. You think mine is the version & or does that matter? The first time I can look under it I will look for a label somewhere. Thank you, I had no idea if tires were correct size, ( they are ), If it had shocks and or air bags ect.............
Deznan
