Brakes
Mar 5, 2013
63
5
Hutchinson KS
Looking for the web site that has the good brake pads
I seen that some say the factory pads are not the best and a lot of the riders on here said that they use a after market rear pad.
Can some one post there web site
Thanks Bill & Chris
I see a lot say to ADJ. the parking brake
How is that done can any one let us know
Thanks Bill & Chris
Parking brake adjustment should be fairly simple... there are two adjusting nuts under the pivot point of the PB handle. The nuts are on threaded adjustment rods. Tighten both nuts toward the back of the trike...start with .25 inch ....then see how it works. You will probably have to raise the trike. It is tight under there, and could be a pain getting to them!
dhinzman1
