Brake light fuse?
Jun 6, 2021
URBANA
The brake lights on my 2016 Harley TriGlide seem to have stopped working. I think it is a fuse problem but not certain as the brake light bar on the tour pack works. I removed the light covers and checked the bulbs and both seem to be good. I even checked using the hazard switch and found both bulbs to be working. Where can I find the brake light fuse on this model? I uncovered the left side panel and found a small fuse box that had nothing about a brake light fuse in it.
Hi Jonathan and Welcome to Trike Talk
Some of the trikes use the P&A fuse, some use the BCM to control the brake lights
Have someone hold the brakes on and pull the fuses until the brake lght on the tour pak goes off
It seems strange tho that those lights work but the actual brake lights do not
Have you had any other strange problems or any work done on or near the lighting?
JazzInTN
