Brake dust deflectors
Sep 8, 2010
4
DC area
Has anyone found the correct brake dust deflector for our 2009 Stallions? Not sure that's the right name. The deflector mounts between the wheel and the Disc. I have deflectors on my Ford...my front wheels stay as clean as the rear on the truck. Sure would like a set for the Stallion. TMS has always been good about answering my questions but I got no reply to this one. Anyone??.
I believe those are aftermarket and they are said to increase the heat of the breaks. The real solution is to change the pads to a ceramic in which the dust is white to clear, but I understand they don't make that pad (or they did not when I was looking) yet for the Stallion. Someone may be able to chime in if they found a ceramic pad yet.
I have the deflectors on my wife's Mercedies and they worked good, then I found the correct pads and took them off.
I,ve not seen deflectors big enough for the Stallion rims. The rear brakes are ford fusion and dustless pads should be available for them. The fronts are another story as far as pads go.
on one of my trips to TBMS I ask them what kind of brake pads?
there answer is
front -- Wangner ZX606 - - ST06-BR00-0180
rear -- 2006 Ford 500 - - - Ford # 7F9Z-2200-A
there answer is
with that if you should be able to find dustless pads.
Coach Buddha
