Bleeding Brakes
tourman
250+ Posts
Jan 20, 2012
318
101
St Paul, MN
Mr Sister
Anyone know the procedure to bleed the front/rear brakes on a 2005 Goldwing? It has linked brakes Roadsmith kit
Not sure how Roadsmith route the rear brake pipes but the standard procedure is as follows:
Bleed Right Front using Brake Lever.
Bleed Left Front using Foot Brake
Bleed Left Rear using Foot Brake
Bleed Right Rear using Foot Brake.
Assuming you have not changed any Brake Pipes it can still be a challenge and it is None ABS.
Did my GL1500 recently using the above. Bear in mind the seals in your Master Cylinders are now 10yrs old as were mine at least but new seals made a big difference.
Others on the forum may offer a different suggestion, it just worked for me.
Dragon warrior
