I have a 2007 GW Trike with a Champion Solid Axle kit and was wondering what is the best to jack it up off the floor without messing something up so I can inspect and/or perform maintenence. How do you do it and what should I watch out for?
I have a 2003 Goldwing Champion trike. Anytime I would change the oil, I will take the floor jack, place it under dead center of the trailer hitch, and lift one rear wheel just off the ground. This gives you just enough room to place a oil pan underneath the oil drain area, plus you can turn the left rear wheel so the driveshaft can be greased. I've been doing this for years and have never had a problem.
Ride safe.
