anyone using BB's in tire for balance??
Dec 14, 2012
486
116
Washington, IL
Mike
had a fellow down in ga. tell me he uses BB's in his tires for balance???,,,ya- he said he uses them in motorcycle ,car and his truck says he's been doing so for years with good result's ,,,,, just wondering if anyone here has head of this or tried it?? I can't see why it would not work but also can't think of a good benefit over say dyna beads..
magoo
I'm surprised he's had success because BB's are usually copper which is very soft. I would think they would grind each other up and wear quickly when rolling around inside of tire.
Dynabeads are ceramic which is extremely hard. Dunno.
I retired from the tire business and will tell you the bbs will work. We used golf balls in truck tires for a long tome. They would out last 2 sets of tires. In some cases it would take a little time for them to settle in and balance the tire until then you had a vibration. bbs are harder than golf balls, lead fishing sinkers work also, even if they wear down the material is still there. I know a trucking company that tried gear oil, it balanced the tires but ruined the inner liner of the tires. Do not use any kind of oil or water.
I believe they are copper plated steel to keep the steel from rusting.
There was a company selling sand in a plastic bag for balancing. It worked but would stick in valve core and let the air out. BBs work and will not let the air out.
BB in tires.
magoo
I tried BB's in wife's car. It seemed that every time the speed changed I had a small vibration for 2-3 seconds than smooth again till next speed change, so I took all the beads out and went to regular wheel weights.
Lots of work for nothing,but I tried it.
Ride safe Bob
When I was a kid I almost knocked my eye out with them , Other than that and breaking a few windows' No.. :AGGHH:
mad maxxx
