- Nov 18, 2008
- 206
- 5
ZOOKultraboy-
Thanks. On the rake kits, my recommendation is stick with the Champion EZ-Steer. Thats what Champion and Motor Trike uses and its the heaviest (construction wise not weight) and best built and yes it does have all the factory mounting points you'll need to bolt it right on and remount all your stock items. PM me and I' make you a deal on one. Same goes for any other member.
Also....do not go past 4.5 degrees. On the FLHs more than that is just too loose and is not needed.
How much lead time do you need?
