Air Cleaner Change
May 2, 2008
108
17
Erie, PA
Clarence
i have 25600 miles on my 08 goldwing trike. should i change out the air cleaner and spark plugs or can you go longer on mileage? 🤷
i have 25600 miles on my 08 goldwing trike. should i change out the air cleaner and spark plugs or can you go longer on mileage? :Shrug:
Hard to say about air cleaner, depends how dusty the area you ride in is. I change mine every 2 years (30,000 miles) and plugs every 15,000 miles, but they don't look bad. Some say that if you're MPG hasn't changed then you don't need to change either.
Re: air cleaner change
Most I ever went was about 42,000 on both and they were really due. I think 30,000 on both would be a good target.
As previously mentioned, air quality where you ride may shorten that time and if the gas mileage starts falling off I'd sure inspect the plugs at least.
dhinzman1
