Added Tail Lights on Fenders
Mar 7, 2017
100
39
Bournville, OH
Hank
I have been thing about installing and brake light / stop light on each rear fender, something to have more visibility when braking and riding after dark, plus it will would need to be visible from side view, we lose side view of rear lights once trike kit is installed.
are there any good rear light fixtures out there that fit the curve of the frankenstein fender?
Hank
Hank
The LED Run-Brake-Turn lights can be used as just brake lights if you wished. You can see them HERE.
They will fit the curve of your fender, as that is what they are made for, to conform to various curves.
Do you have the full fender or half fender?
I have a full fender, I dont want tomb stone type lights, May check some swap meets to see if I can get 2 factory 03 harley tail lights and in stall them, that way I will be staying with the look it has. I think it would look funny with different tail lights on fender than what is on middle fender.
Hank
Hank
I was looking at some parts catalogs that I have and the only ones I found that look like they'd work with the fenders were LED iron crosses as they were flat on the back. The full fender looks like it has a flat area on the back, probably not much of a radius.
tony29
