ABS light
At the end of a 50 miler today the ABS light began flashing and continued until I parked. I have zero experience with the ABS system. Naturally, the next time i started up the light came on as expected and went out when i started moving, so it seems fine again. Is something starting up in the ABS that I need to have checked out? Anyone have a like experience that can shed some light on this minor mystery?
Well, it's safe to assume your conversion utilized the bikes ABS system. I would have someone check the gap tolerance on the trike portion. If it's shifted, or moved any, it could be slightly outside of the proper tolerance. This will usually only create a noticeable issue as you get closer to highway speed. It may be a 15 minute fix.
Anything outside that, I'd guess some good ol fashioned diagnostic testing will be needed. Hope this helps at least somewhat!
Thanks. May be a good starting point.
Thanks, appreciate.
jhlesher
