30T Change
19jman
20+ Posts
Mar 27, 2022
25
33
LHC, AZ
JMan
Good afternoon,
I appreciate all of the information & insights I've run across the site since becoming a member. I transitioned to a 2012 Tri Glide last April. Sure, do miss my 114! I’m considering running the 30T sprocket, to gain more umph, until I can swing new cams. Looking for pros & cons. I have to replace the shifter shaft, so I’ll be in there anyway.
Thank you it’s much appreciated.
Harley Triglide stock sprockets
Your stock 2012 Triglide should already have the 30 tooth sprocket part # 83595-11 30T
The 2009 and 2010 came stock with the 32 tooth sprocket.
If you want more info look up Harley OEM parts and check it out. The site will ask what year, model of bike and then show a listing of all parts available.
Your sprocket is # 10 30 T
Medium
wzejda
