What's the best tire pressures for a smooth ride and the best air shock pressure rider only 180 lbs.
36 pound in the front proximately 25 in the rear tires for the air shocks just experiment…
That's what I ran my 2014 at on the tires, be real careful on that shock it does not take much to make a big difference because it airs up quick it is best to use a manual pump.
Jack up the front wheel off the ground, you should get a little resistance when turning the bars. I changed my fork oil when I bought mine last year and it made a world of difference. I run 25 psi in my tires but I have coil over rear shocks from pro Action 14”. No more screwing with them air pressure
What weight oil did you put in the forks? Anybody put Supershox on their Tri glide. We have a HD dealer in the area that sells and installs them.
