2014 triglide
36 pound in the front proximately 25 in the rear tires for the air shocks just experiment…
That's what I ran my 2014 at on the tires, be real careful on that shock it does not take much to make a big difference because it airs up quick it is best to use a manual pump.
Just to add .. on the air shocks you need a No-Loss air pump with a gage.. Using a regular air gauge air pump you’ll lose more air than you put in by just unscrewing it off the valve..
I have a Harley air pump. My concern is that the front seems to wobble when going slow on bumpy roads. I just bought the 2014 and it has 9k miles. The steering stabilizer should be good. I had a 2010 with raked front and independent suspension that I had since new that's what I got used to. I Got rid of it because had it a long time and wanted to try the MT Rushmore model.
Hi Jim, :welcome:to Trike Talk
36 PSI in the front tire, 22-25 PSI in the rears
Air shocks will be a different animal, play with it til it feels right to you
Jack up the front wheel off the ground, you should get a little resistance when turning the bars. I changed my fork oil when I bought mine last year and it made a world of difference. I run 25 psi in my tires but I have coil over rear shocks from pro Action 14”. No more screwing with them air pressure
What weight oil did you put in the forks? Anybody put Supershox on their Tri glide. We have a HD dealer in the area that sells and installs them.
I think it was 10wt belray, I did add 1/2 ounce more than recommended.
On my 07 Electra Glide i mixed the Screaming Eagle with \Heavy fork oil from the dealership and it worked good
dhinzman1
