2013 Stallion A/C not blowing cold
Mine didn't blow out cold air from day 1 and it is a 2013, as a matter of fact it blew out hot air. Apparently a valve was stuck and a electrical box of some type that controls it never worked from the factory.
Any solutions or ideas on what will cause the A/C not to blow cold....not that it is needed right now......thanks
take it to any auto mechanic. A/C repair shop.
Good luck with that. Some of the components are specific to the Stallion and are known to fail. Its not that they are one off pieces, but they aren't that easy to be had at just any auto parts store. It is normally one of two problems, the switch panel assembly on the left side dash or a controller located in front of the right rear wheel. A call to TBMS will get you an answer and parts support.
Try turning the AC knob until you feel a Click. AC only works when you pass that point of indenture, asa in Click!
Re: 2013 Stallion A/C not blowing coldride....happy wife.....happy life
All fixed....nice job by Cherokee Trikes in Greer SC.....don't need the cold right now but the brakes are all set... a defective distribution valve....hoping to head to Fl in the next week or two....the wife loves her ride,,,happy wife....happy life
ride safe
ride safe
it is a little warmer her
I was experiencing poor heat this winter. I noticed that the control panel said "Vantage Air Conditioning". I looked them up and gave them a call. I asked if they could tell me which system was installed in my Stallion. The technician told me I had a Gen II. Then he asked me what problem I was having. I told him and he told me the heat control pot was defective. The part cost $5.00 plus shipping and about 20 minutes to install. The heat works great now. Hope this info helps someone.:clapping:
Good job on finding that solution. Thank you for posting.
Roger71!!
