14" meat hooks on 14 Tri Glide
Gvette85
5+ Posts
Oct 2, 2022
8
11
Florence
I just put 14" meat hooks on my 14 Tri Glide and the upper brake hose is way tight. Even after re-routing its tight.Any sources for an upper brake hose ,4 or 6 inches? My searches only come up with full sets of extended hoses.I just need the hose from the handlebar master cylinder to the connector block on bottom of the triple trees.
Magnum shielding should be able to hook you up.
Just buy yourself a couple of AN3 Banjo flare fittings and get any length hose you want. Put a banjo fitting on the Master cylinder and one at the splitter on the lower tree.
Thanks for the tips guys. I removed the fairing and upper brake hose,ran the hose behind the fork tube instead of in front, which was a much better path,and had ample length.Reassemble,bled brakes and enjoying the ride.Love this forum !!
ShonaZiemb
