What trailer do you use to haul your trike?
After purchasing my Tri Glide in September of 2023, I put about 400 miles on it before winter came early.
Over the winter of 2023/2024 is when I started the transformation from vivid black to the custom HOK Kandy Brandywine. I put 5,000 miles on it last year with quite a few modifications through this time.
This winter, I (of course) did more including a new front wrap style fender.
Getting to the point of this post!… lol!!… during this time I wondered if it would fit the open trailer I had for years (and used for my previous bikes).
Today, I can confirm and will say, that it “comfortably fits perfect”!
I would not recommend any shorter, nor any less wide than what I have. (5’ wide would definitely be EXTREMELY close! - too close for comfort in my opinion).
What I have:
A 5-1/2 foot wide, 10 foot long TSC carry on brand open trailer. (Some modifications done to it: double rear gate, custom spring inside the top tube rails for ease of assisting the gate back into position).
Again it fit perfect!
I just trailered it to a custom detailer that does a professional Ceramic coating. This way that paint will have the best protection on that paint.
I have a Condor Aluminum wheel chock at the front, multiple tie down points, but after the first time confirming fitment and first time it’s been trailered, I will now add an E-track rail system to the rear for a better rear tie down points.
But just wanted to say how my 2014 Tri glide (with a 9 degree take kit from @Papa Zook) fit on my trailer and personally would not recommend any smaller than what I have.
Recap: 10’ long, 5-1/2’ wide would be the smallest that it would comfortably fit.
Pics:
Any one preferring a low clearance, enclosed trailer option (that doubles as a secure, weather proof storage trailer) may want to look at IronHorse Trailers.
We have one for the wide, low, long Indian Roadmaster Hannigan Trike Mod, and love it - loaded trailer tows great behind a truck, large SUV, or RV.
The Iron Horse trailers handle loading unloading low trikes very well - they have a long 52" fold down rear ramp, and also have a low 10" ground clearance due to torsion axles. This allows for a very flat loading profile for low trikes.
The trike trailer weighs only 1,170 lbs (premium aluminum and fiberglass construction). Holds one trike or two large road bikes.
2022 Ironhorse Widebody single axle aluminum fiberglass 3500 GVWR white.jpgIronHorse Wide Body Trailer Spec Sheet.jpg
dhinzman1
