New from Maryland
Jun 29, 2025
1
2
Maryland
Dan
From Maryland, and I just inherited a 1986 Honda Goldwing with a trike kit added to it. No clue what kit yet. It has been a long 5 years for the estate to settle and getting ready to get the bike from Ohio to Maryland.
Now to figure out how to do that inexpensively since it currently doesn't start (stored with gas in it until I moved it into storage, and the front tire needs aired up (after I reset the bead).
Then to get it checked out and determine if it is even worth it.
Hello & welcome to Trike Talk Dan. :)
It will need a little work to get it road-worthy. Is it CFI or does it have carbs?
Timing belt change and fluids are a must change. A new battery, fuel filter and drain the old gas, check the tank for rust. This is just a first things list.
Welcome to TrikeTalk Dan! It will be an interesting project but getting it back on the road is doable. Just take your time.
Welcome Dan post some pictures so we can help you "ID" the conversion. You can get it transported by companies that do that. Go on line a google motorcycle transportation co. Then start doing some research.
Should be around 4 to 6 hundred but my reference is a couple of years old.
wzejda
