2024 CSC Encore
Pem
May 1, 2025
8
3
Illinois
Pete
Brand new 2024 CSC Encore, 600 miles. An annoying, loud squeaking noise from the rear end when reversing using the reverse function or rolling back in neutral. The same noise is present when moving forward between 0-10 mph. Working with CSC and a local certified CSC dealer, so far, no luck pinpointing issues.
Has anybody experienced this same issue, and if so, what was the root cause?
Local dealer found a glazed right rear brake pad not even 1000 miles, chaged it out. Noise went away for about 75 miles now it is all back again. Taking it back again soon to see what else is the issue. The bike even squeaks when turned off completely and you push it slightly forward from the rear forward.
ShonaZiemb
