Eaglelights Sunburst LED Lights
Jul 21, 2024
51
58
Sykesville, MD
Chuck
I just installed the Eagle Lights Sunburst lights on my 23 Tri Glide Ultra. They worked when I tested them without the passing lights plugged. When I connected everything the Sunburst lights only work when the directional lights are on. The Sunburst lights do not come on with the passing lights. Has anyone run into this issue before?
I just installed the Eagle Lights Sunburst lights on my 23 Tri Glide Ultra. They worked when I tested them without the passi g lights plugged. When I connected everything the Sunburst lights only work when the directional lights are on. The Sunburst lights do not come on with the passing lights. Has anyone run into this issue before?
I have the Custom Dynamics on mine and I will assume Eagle connects the same way and include “splitters”.
There is a good possibility those splitters (or even possibly the lights themselves) may be “pinned” wrong?
As soon as you connected the directionals back up, its possible it then changed the polarities.
Double checked those “J-connectors” and may need to call Eagle tech line.
As soon as you connected the directionals back up, it changed the polarities.
Thanks for the suggestion. I plan on calling Eagle on Tuesday. I should've known better than to install them on a holiday weekend.
