What Shocks are you using on your Triglide
Trampas
1000+ Posts
Aug 27, 2016
1,069
570
Des Moines, IA
James
I'm just curious what everybody is running for shocks on their triglide, I'm still running the air shocks on my 2018. Have seen a few that are still running air shocks and now they have the coil over shocks and some are happy with these.
So what are you using for a shock and what brand and why that brand???
Still using air shock or coil over from harley say so, just curious????
I know my 2002 road king rode really good with the air shocks, my 2016 and 2018 triglides rode so so. Just curious since harley has been using air shocks for many years I wonder it the triglide shocks are the same as what they use on touring bike, if so I can see why the ride is not as good, not a stong enough shock IMHO for the weight of a triglide.
I have check in with DK on their next gen shocks and good reviews, have also check into the super shox, not sure about this they said I need the 14.5 shock for a good ride, the only trouble is I have to buy another s pipe from them for it to work and I can't use my lift kit from DK that have on it now, would have to go back to stock bracket, also I have to cut some pipe off to get it to work, sounds like to much work IMHO and then from what I have read it is only a 3 inch travel on a 14.5 shock form super shox, might be a good ride and maybe not.
All for now Trampas
P.S. can't wait to see the replies on what everyone is running and why
I ride a Freewheeler so you may not even consider my opinion, but unless you pack a heavy load, they should be very similar.
Now to be fair, my budget has seldom allowed me to get the “very best” of things. My selections are based on bang-for-the-buck.
I installed the Bitubo twin adjustables about three years ago. They are a big improvement and I have no complaints.
From what I have read, there are better shocks out there (at about twice the price).
I’m running the 14” ProAction shocks.
These will be “dialed in” from them to fit your riding (weight & 1 vs 2-up) but you can still easily make adjustments to further enhance the ProAction shocks.
DK Customs also pushed the ProAction quite a bit before they came out with their NexGen shocks. These are GREAT shocks and I have had them on my previous bikes too. A total game changer, for sure!
Made in the USA in Beaver Falls, PA.
You’re going to hear many other companies mentioned …. most are indeed a huge improvement over the stock shocks.
14.5 Super Shox's
Made in the USA
Tailor fit for your bike and riders weight.
Money back ride comfort guarantee.
Warranty from defects for life.
The company that makes these shocks has been in business for years and that's all they do.
Had the 14" Pro-Action with DK's comfort lift kit on my 2018 TG. Much improved over the stock air shocks. But DK designed, worked, modified and adjusted various designs to get their NexGen shocks. That is what I put on my 2020 TG and now just got a new set on my 2024 TG. Having ridden both the Pro-Action and the NexGen I can say imo the NexGen is superior. Based on Kevin's recommendation I went with the 13" and the convertible comfort lift. Kevin told me the amount of travel on the 13" is the same as it is on the 14". He can explain why much better than I can. It did lift the rear of the TG about 1 1/8" to 1 1/4" from stock and I'm very happy with that.
I've not ridden the SuperShox and I'm sure it is a fine product. But for my $$ and the fact Kevin is a great resource for the forum and a also a personal friend the choice for me was simple and I am very happy with the results.
BTW I also just installed the DK intimidators in the front forks. I've only ridden them about 100 miles but I can definitely tell an improvement.
Legends lift kit . Legends cartridges up front, Legends Revo As on the rear . Very happy with the choice but not a cheap proposition. Worth every penny - smooth ride, easy steering steady at 90 mph.
For me I decided to go with the DK Customs Nex Gen shocks and already had installed the rear lift kit like I had my my previous trike. With that said both were great improvement on handling and the ride. The Nex Gen shocks were already set up however I wanted to experiment a little to see if changing setting makes any difference. Generally I ride solo so changing setting rode a little firmer. Only down side is having to adjust the setting from the top of the shock....just my 2cents.
14.5 Super Shox's
Made in the USA
I too will be looking at the Super Shocks. As you mentioned, 4 good reasons.
This company has been working with the World of Outlaws Sprint Cars for many years with great success. The suspensions on these cars go through hell on the tracks. Sammy Swindell has them on his cars as well as others.
Thanks for all the replies guys, with over 2,000 views I would of hope for more replies and no one said if they are running stock except me, guess no one wanted to post I guess, their are quite a few regulars that didn't post but I won't name them but do apprieciate the replies that I did get, thanks for sharing the shock you are using and much appreciated.
All for now Trampas
Trampas... There is nothing wrong with running stock shocks. I ran stock for four years and they gave me great service, handling and comfort, once adjusted correctly. I read all the great things about these expensive shocks so I figured if I could improve things I'll spend the money. To be honest I see very little difference in the expensive shocks over stock. And yes, they are adjusted correctly. I found the same with tires. I have tried big name expensive tires and good quality less expensive tires on the rear. Again very little difference in ride or handling. These are motorcycles, they are not going to ride like a car. IRS would help but there is only so much you can do. What you just read is MY OPINION. If people reading this disagree please continue to do things the way you are now. I'm not looking for a ration of shit.
I put 14" Super Shox a couple of years ago on my 013 Road Glide and noticed a difference. There a good product, but decided not to change out my stock shocks on my 019 Tri glide. We feel there ok when riding two up, the crappy bridge abutment certainly are a pile driver though!
I just don't think any of them are really worth the bucks for a solid axle Harley Trike, IMHO (at least the later years). Of course I've only got about a 1000 miles on this used trike and have never ridden any other trike, so probably my opinion is just like you know what? Everybody's got one!
14" Pro Action here. Also had them do the front suspension. I've been riding for over half a century and these and the 9 degree rake kit are the best thing that I have done to a bike.
I’ve got the exact same set up as you:
PA 14” rear shocks, front fork kit and the 9* rake kit (from @Papa Zook) on my Tri Glide.
What an absolute pleasure to ride and great combo!!! 👍🏻👍🏻
14.5 Super Shox's
Made in the USA
These are the shocks I run on my 13 Triglide for the same reasons, the ride and handling are a dramatic improvement over the leaking air shocks.
All for now Trampas
Been running ProAction frt & rear since my 16 Tri& now my 20 Tri. Life time warranty & built by a guy who is an expert in the field. Worked for Ohlin many yrs. In all the yrs I have had them & over 70,000 miles, only one issue.Called George & sent them over to Pa. & it was fixed & returned in record time no charge. it was down less than a week total. HD has never had a decent shock every one I had ,shocks were always replaced with a better brand
Ok I think you guys are probably right! I just pulled my 14" Super Shox off my Road Glide and shipped them back to have them reworked to fit my 019 Tri glide.
We just drove Hwy 20 in WA to Winthrop one of the roughest roads I've been on in my almost 70 yrs! (highest gas taxes next to CA I might add!) One bridge I thought was going to launch the Wife off the trike and rip the suspension off!
So I will be installing the Super Shox on the my Trike (it might take me awhile as it's a PITA to do). So I will give a total unbiased review when I get them installed.
