payzac
40+ Posts
My reverse is not working .I have reset the trip switch and it keeps tripping when I try reverse
What could it be
In advance for info
Randy
What could it be
In advance for info
Randy
What could it be
In advance for info
Randy
What year Triglide...If you are handy.......Pull the motor out open the top of it and check and clean the brushes......Sometimes they stick and have to be realigned.. But that usually is a temporary fix...
it is 2017 I thought it might be the brushes
will need to take out and look at it
Might know it would happen while I am down in Fla. without all my tools
Give it a whack with a rubber hammer, if the brushes are sticking, it may make it start working again until you can rebuild it
See...Jack you are a gentleman....I was thinking of a medal hammer, Being i work caveman style I forgot all about using a rubber hammer..ThumbUp...
Fix it til it breaks Bob![]()
My motto was when someone would ask..How tight is tight?...My reply was just tighten till it strips......Then back off a quarter turn.......
Nothing you can't fix with a hammer
Tapped on reverse motor and working now:clapping:
Thanks for input from everyone will change out when I get back up north
Thanks again
Randy
What could it be
In advance for info
Randy
What could it be
In advance for info
Randy
Either use the forum search feature or go to the Harley Triglide forum and search "triglide reverse not working" and you'll find several good threads with the best way to cure your problem.
