Restoring a 30 year old GL 1500 Hannigan trike
Aug 18, 2023
3
2
Mooresburg, TN
Mickey
Hello to everyone from my home in Upper East TN. I have purchased my first Trike, a 1994 GL 1500 with a Harringan conversion. It has 50K on the odometer. I have ridden 2 wheelers since 1967 but this is a NEW adventure for me. I have 2 questions I need help with.
1. There is almost no clearance between the right rear tire and the fender. In fact, at some time in its past the tire has worn a hole in the fender. Is there an adjustment to fix this?
2. The Aux gas tank has a hole and I need to repair it (yes I know how dangerous it is to weld a gas tank and I also know it is aluminum). Can I get a manual from Harringan , are there any video’s on removing the aux tank?
Thanks for any help.
1. There is almost no clearance between the right rea tire and the finder. In fact, at some time in its past the tire has worn a whole in the finder. Is there an adjustment to fix this?
2. The Aux gas tank has a whole and I need to repair it (yes I know haw dangerous it is to weld a gas tank and I also know it is aluminum). Can I get a manual from Harringan , are there any video’s on removing the aux tank?
Mickey, Welcome to Trike Talk 👍👍.. Depending upon where the hole is a you can fill the tank with water and then weld…Or like I’ve done many times before..A good layer of J P Weld …Will work!..
Thank you all for your responses
Water is not a good option. The welding process can cause water porosity to form in the weld and make the weld unsound. A better option is to use an inert gas (nitrogen).
The quest Is not how to fix the hole (know how to do that), how to get the AUX tank out of the Harringan trike so I can TIG weld it.
Welcome to Trike Talk and your first post
Depending on your skill level, welding the tank after a good cleaning to remove rust should be in order
No rust it is aluminum. The quest Is not how to fix the whole ( know how to do that), how to get the AUX tank out of the Harringan trike so I can TIG weld it
:wave4:Welcome to Trike Talk Mickey!!!
Hello & :welcome: to Trike Talk. :clapping:
Thank you for your response.
I haven’t thought of that but you are correct that would probably work. But still I would like to get the tank out and inspect it. It is 30 years old and the hole was put there when a previous owner hid an object in the road and knocked a whole in it. Also the AUX fuel pump relay has developed a short. That was a frustrating job to replace the 30-amp main fuse.
Can anyone tell me how to remove the body from the trike conversion so I can make the inspection and repairs needed. I have rebuilt many MGB's and small general avation airplanes, but never a TRIKE.
Stitch61
