Fuel guage always reads full
May 8, 2011
755
20
Peru, IN
Leon
1999SE. GL1500 goldwing with roadsmith kit, with aux tank.aux tank fuel transfer doesn't work. . Does the aux switch position transfer fuel to main tank when the low fuel light comes on OR does it feel the engine? Is there a easy fix?
I'm going to replace the fuel pump assembly, as I have a new one .pictures later
Yes, it transfers fuel from the aux tank to the Honda fuel tank. I've replaced a few over the years and it is an easy fix.
'99 GL1500SE, with roadsmith kit. can't transfer fuel to main tank
see jppeg. i believe this is thw wires going to the transfer switch. main tank is empty. with transfer switch is in the bottom position. but its not transfering fuel to main tank. i don't see a low fuel light on the dash. how do i make this a transfer fuel, when i manually select the lower position on the switch. thanks. lb
Dan2003
