Installing Thunder Torque Inserts™ - More Torque - Deeper Tone - Dyno Proven
Not Sure What Size You Need?
Go HERE to Shop Thunder Torque Inserts™!
Optimize Your Exhaust HERE!
I had to change my head pipe gaskets over the weekend, on my Indian roadmaster CSC kit while I had the exhaust off, the mufflers are from CSC the baffles are like super trap style disc I just didnt like them, so I found a old set of screamin eagle mufflers took the baffles out cut them to fit my mufflers, went for a ride they sounded like Shit & had no Balls I had a new set of 3" thunder Inserts drilled a hole put them in went for a ride sounded better still a little bit flat, took & turned them the other direction with the bolt part sticken towards the back Sounds great & runs really Good, Its really Hard to believe that these could make that much of a difference :D
Great to hear.
Yeah, it is amazing how well these can improve sound and power.
Glad you experimented with the rotation and found what works best for your set up. :clapping:
Ride Free,
