Oil Level and Oil Temperature Gauge for Freewheeler similar to that for other HD FL
lingone
30+ Posts
Apr 29, 2022
44
37
Veuxhaulles sur Aube, France
Colin
I went to order the HD oil level and temperature dipstick (Part 62700180), but find it does not fit the FLRT Freewheeler, despite the catalogue saying it fits all FL models.
Does anyone know of one that fits a Freewheeler, and a part number?
I went to order the HD oil level and temperature dipstick (Part 62700180), but find it does not fit the FLRT Freewheeler, despite the catalogue saying it fits all FL models. Does anyone know of one that fits a Freewheeler, and a part number?
I've looked at that part as well. Like davekp said, can you tell us why it doesn't fit?
The Harley Davidson website says it does not fit any of the HD Trikes. I do not have the gauge to test against my Freewheeler to see if it does fit, HD just say it does not.
Oil temperature is a " nice to have" but means little. Head temperature is more important. Your better off investing in A1 Cycles oil pressure gauge. Especially as the stock sensor can be glitchy. HD also says that the Airwing fender rails wont fit the FLRT but I installed them just fine.
My best guess is that the trikes are “upright” while all other FL’s “lean on” a jiffy stand.
While the temp part of the gauge might work, the oil level feature would be off…
Why the motor company doesn’t make one for trikes is beyond me.
Stock oil stick on a Tri is marked, "Upright" & "Side stand" My guess for a trike or 2 wheels...:Dorag: Easily fixed . Check oil with stock stick, then make a line on new stick for full. etch a line
If the only issue with using this gauge on a trike is the oil level, then you should be able to note how many segments are lit when you verify the engine is filled to the proper level. Be sure to check out the reviews and ratings, however. Some folks are not too happy with their purchase.
Stock oil stick on a Tri is marked, "Upright" & "Side stand" My guess for a trike or 2 wheels...:Dorag: Easily fixed . Check oil with stock stick, then make a line on new stick for full. etch a line[/QU
What you say about the oil stick on a Tri being marked "Upright" and "Side stand" is very interesting. I presume the level gauge (Part 62700180)
will fit but will not show the true oil level as the bike is upright, and it measures oil level on "Side stand". It fits but does not read true. That is easily compensated for by looking at what it reads when the oil level upright is correct using the original dipstick.
Oil Temperature and Level Gauge - Latest
What you say about the oil stick on a Tri being marked "Upright" and "Side stand" is very interesting. I presume the level gauge (Part 62700180) will fit but will not show the true oil level as the bike is upright, and it measures oil level on "Side stand". It fits but does not read true. That is easily compensated for by looking at what it reads when the oil level upright is correct using the original dip-stick.
I have now received the oil gauge dip stick (Part 62700180) and it does indeed fit the Freewheeler oil dipstick threaded opening.
As most of us surmised, it will record oil temperature (°F or °C), but it shows a full Freewheeler oil tank as at level 7 hot or cold. If the Milwaukee Eight engine was lower than this, it is clear that the gauge would show level 7 but flash a low-level warning.
As far as I am concerned, I am happy that level 7 (hot or cold) indicates a full oil level, and level 7 flashing indicates a need for a top up.
Does anyone see a problem with this? It warns me if I need to top up, and I can use the original dipstick to establish how much I need to add.
I have now received the oil gauge dip stick (Part 62700180) and it does indeed fit the Freewheeler oil dipstick threaded opening. As most of us surmised, it will record oil temperature (°F or °C), but it shows a full Freewheeler oil tank as at level 7 hot or cold. If the Milwaukee Eight engine was lower than this, it is clear that the gauge would show level 7 but flash a low-level warning. As far as I am concerned, I am happy that level 7 (hot or cold) indicates a full oil level, and level 7 flashing indicates a need for a top up. Does anyone see a problem with this? It warns me if I need to top up, and I can use the original dipstick to establish how much I need to add.
I believe your are blazing a new trail here. Please, by all means, keep us informed as how this is working out. Seems a lot of trikers are really interested in it including myself.
Seems to me it is a waste of money, so you are saying you will need to have your original stick with you so you know how much oil to add?
That 4 sure would be a non starter for me JMO
I'm glad you said it....A regular dip stick works just fine for me, Anything else sounds like a Rube Goldberg toy....:Shrug:..
Have no issues with the OEM stick . Just added a sharpie mark on the upright side so I don’t get confused . And that can happen at any time I have a choice :xzqxz:
Whenever theres a choice i have a 50/50 chance of being right ...But theres always that 90% chance of me being wrong...:D..
The benefit of the digital gauge is that I do not have to unscrew the dipstick, wipe it clean, reinsert into filler hole, screw down fully, and then unscrew to inspect level on the dipstick. With the digital gauge it shows solid level 7 as full, and flashing 7 as needing a top up. I am sure I will be able to calculate empirically (ie. trial and error) how much oil I need to add to go from 7 flashing to 7 solid (full). The benefit is not having to inspect the fixed dipstick to find out if the motor is either full or in need of a top up. Personally, when inspecting a dipstick (lorry, car or motorbike) I always seem to get at least a drop of oil on the engine, however careful I am.
However, as always it is a matter of personal preference - I am happy just to know by pushing a little button that it does not (or does) need a top-up.
Update on electronic gauge dimensions
Here are the results of my comparison of the OE and electronic dipsticks:
With HD electronic gauge (readings on jiffy stand only)
4 Full
5 0.25 quart 0.25 litres
6 0.5 quart 0.47 litres
7 0.75 quart 0.71 litres
8 1.00 quart 0.95 litres
Range on dipstick for adding a quart/0.95 litres on jiffy stand: 0.75”/19mm
Dipstick measured from base to full on jiffy stand: 3.32”/82mm
Dipstick measured from base to adding a quart on jiffy stand: 2.49”/63mm
Dipstick cap to full mark on upright:3.52”/89mm
Original dipstick (readings on jiffy stand and upright)
Original dipstick range for adding a quart/0.95 litres on jiffy stand: 0.75”/19mm
Original dipstick measured from base of dipstick to full on jiffy stand: 2.67”/68mm
Original dipstick measured from base of dipstick to a quart on jiffy stand:1.95”/49mm
Original dipstick cap to full mark on jiffy stand:3.52”/89mm
Original dipstick range for adding a quart/0.95 litres upright: 0.67”/17mm
Original dipstick measured from base of dipstick to full upright: 3.029”/77mm
Original dipstick measured from base of dipstick to a quart upright: 2.4”/61mm
Original dipstick cap to full mark upright: 3.08”/78mm
Conclusions
Upright scale “full” is 0.44”/11mm higher than jiffy full. 11mm is equivalent to 2.6 bars on the electronic gauge. Needing a quart (0.95l) upright is 0.52”/13mm higher than jiffy scale. 13mm is equivalent to 3 bars on the electronic gauge.
On the OE dipstick (4.75mm on jiffy scale, 4.25mm on the upright scale) 1 bar on the electronic gauge is equivalent to 0.25 quart/0.24l.
Therefore, when the electronic gauge shows bar 4 (the lowest of the four bars) as solid the oil level is full. When bar 4 flashes it requires a top-up of at least 0.25 quart/0.24l.
There is also a page below comparing the two different dimensions. It would appear that HD could produce a Trike 'upright' electronic dipstick by lowering the sensors on the dipstick by around 12mm. Not rocket science, and I am sure there would be a demand. Meanwhile, I am happy to use the electronic dipstick to let me know if I need to top up at all.
Dipstick Dimensions Comparison
Ive emplaced artillery with less foo-fa-rah.
Thank you for your insightful and constructive contribution.
However, the last line is the one you need to read for a summary - "[FONT=&quot]Therefore, when the [/FONT][FONT=&quot]electronic gauge[/FONT][FONT=&quot] shows bar 4 (the lowest of the four bars) as solid the oil level is full. When bar 4 flashes it requires a top-up of at least 0.25 quart/0.24l." [/FONT]
El Cabron
