trike brake parts
Oct 11, 2022
4
8
Crewe
hi all
just about to take delivery of a 2000 Honda gl1500 trike ,I'm not sure when the conversion was done but having paid out when i got back home i couldn't help but think that whilst i knew lots about the 1500 i knew nothing about the trike
The first thing that sprung to mind was what happens when its due rear pads and discs ,so how do i firstly find out what the rear end is off ?
what's worrying my is i might be left with 11000 worth of unusable trike
thanks in advance for any help
hi all
Post a picture of your brakes, that will help identify them
Don't be surprised if it has Ford 9" drum brakes like a 1980 Pinto. Solid axle likely is a Ford 6.75 integral Pinto axle shortened. Rear universal is likely a big cap Ford 1310 series, thicker caps under the u-bolts retention in rear yoke. Drive shaft might be a GL 1500 shaft cut and welded in a yoke or it might be a splined shaft with 3/8" set screw retainer. Front U-joint is either a GL1500 or Valkyrie U-joint Not junk, it's all available but it will pay you handsomely to know what you have.
Here is a picture of typical Ford drum brakes
Only thing I really wanted to add, this is a left rear brake, long shoes at rear, short shoes in front.
Really a nice picture with no brake dust covering everything.
A great picture for someone who maybe forgot the order. I always lay parts on the floor in a pattern that will aid in replacement, one can get anything for these Ford drum brakes. I do one brake at a time.
Friend of mine decided to reline his old Mustang's drum brakes ... He took all the parts off all 4 drums and put them in a bucket to clean, then realized he had no idea how to separate the parts or to reassemble his brakes with new shoes. He did have clean stuff, but what a mess.
brake drums
I bought the trike ,is any one able to identify what the brake drums are off its a 2000 1500 gold wing with a lehman trike
View attachment 110693View attachment 110694
Looks like a 9" Ford brake drum to me, even to the number 212043-C stamping ... and the fins. I just looked up a 1980 Ford Pinto brake drum but my '92 Thunderbird had the same rear brakes as do a lot of older Fords with drum rear brakes. You'll often see them listed as 1-3/4" wide or sometimes as 1.81" wide shoes. They did play with rear wheel cylinder diameters as a way of tailering them to application. I used to have a lot of info, but after I sent it back home to the original owner in 2019, most of it seems to have gotten away. I owned it 15 years though. If ever replacing wheel cylinders, might have to measure your's.
More Information for ACDELCO 18B21 (rockauto.com)
Post in another thread has some other info you might need someday?
Brake shoes ... 9" Ford Drum Brakes ... Some numbers to help guide you. Most of it is like late '70s or early '80 Ford Pinto, Mustang II, etc. Even up into the '90s Ford used a lot of 9" drum brakes on cars. Your rear axle is a 6.75" integral carrier rear with a stamp steel rear inspection plate, but they came with one of two different gaskets, square looks like a square with 4 rounded corners, octagonal has 8 sides, no curves. Keep in mind that these numbers are from the latest GTL book I had, Many will need to be cross referenced.
You can experiment with other rear wheel cylinders too, Ford made them in several diameters. Bigger will increase braking force while decreasing effort but increases travel, smaller will decrease brake force requiring more effort but decreases travel. It's a balancing act, I played with them but in the end, went back to the sizes as Lehman used.
Description ... Lehman Number ... Vendor Pt No ... Vendor
Brake Shoes GB1118 474RP Raybestos
Lt Brake Adjuster Kit GB1110 2592 EIS
Rt Brake Adjuster Kit GB1112 2593 EIS
Brake Spring Kit GB1124 7157 EIS
Wheel Cylinders GB1122 EW34958 TRU-TECH
12" brake line GB1132 AS312 Papco
30" brake line GB1135 AS330 Papco
40" brake line GB1136 AS340 Papco
Diff. Cover Gasket
(oct) GG0650 RDS 13073 Fel Pro
(squ) GG0650-0 RDS 55323 Fel Pro
Axle Bearing GB1001 RW207 CCRA BCA
Axle Flange Gaskets GG0600 n/a (?) AGS
Park Brake Cable GB1114 370100 ABSCO
Brake Drum GB1120 857 ITT
Axle Stud CS1001 560-186 Papco
Brake Shoe Retainer GB1119 D7TZ2028B Ford
Pinion Seal GS1056 8181 NA (?) National
Axle Seal
(25 spline shaft drive) GS105 3214 National
(23 spline shaft drive) GS1050 3199 National
Park Brake Handle GB1100-0 30011810 Chevrolet
FLH Debris Guard LS1018 300026 Lehman
Sportster Debris Guard LS1017 n/a Lehman
Debris Guard Bracket LB1181 n/a Lehman
Speedi Sleeve (shft drv) GS1058 99181 National
MelT
