Mr Jack TSSM Help Please
19jman
20+ Posts
Mar 27, 2022
25
33
LHC, AZ
JMan
Mr. Jack,
Been riding many years, but moved to trike in Apr. It's a 2012 w 16k. Just this last week the right blinker started hyper flashing on front only. It gave a B1122. I cleared the code and it has not reappeared. I visually inspected bulbs, sockets of all 4 and they all look good. Still need to run a voltmeter.
Is there a procedure for testing the TSSM if it all checks out? Thank you.
-Many Blessings,
JMan
Not that I know of but there is a reset for it, see here
  • Move kill switch to off position, turn ignition on-off-on-off-on.
  • Press left turn signal switch twice, pause, and lights will flash.
  • Press right turn signal switch once, pause, and lights will flash.
  • Press right turn signal switch once, pause, and lights will flash twice.
  • Press right turn signal switch once, pause, and lights will flash three times.
  • Press left turn signal switch once, and light will flash a number of times to indicate an error code.
  • There is 1.5 seconds between flashes to indicate 1st and 2nd digit of codes and four second pause between codes.
  • Press and hold left switch down for five seconds, and light will flash twice to indicate the TSSM is reset.
  • Turn ignition to off.
Have you replaced any lighting on your trike recently?
Hyper flashing can be traced back to bad grounds, poor connections in light sockets and voltage drops also along with combos of led bulbs
TPost
