Raked triple trees in the UK. Recommendations please.
Aug 19, 2022
26
15
Taunton, Somerset, UK
Jim
So I'm at the stage of "oh crap I've got to shell out even more £'s making this Damn trike usable". I currently have nearly 5" of trail & that needs to come down drastically.
So I could do with some recommendations on where I can get raked triple trees in the UK, for a '98 Vmax or indeed any other method to cut off 2-3" of trail (that's cheaper, which I doubt).
if you have some fabrication skills and equipment a leading link is not that hard to make... best part is the trail is adjustable and a lot less close tolerance machining to do
Interesting. I may have to resort to something like this as atm I have no leads on where to buy anything. Thanks.
edit: any idea how I'd work out what strength shocks to use?
not a clue.. sorry..i have had good luck though,, the lower mount is adjustable so u can basically change the spring rate an to is adjustable to change the height.. loaded the axle about an inch above the pivot works well
Terry D
