DNA Hub Removal
Jun 27, 2022
2
1
Jonesborough
I am installing a DNA axle on my 2000 Harley 883 XLH. The belt does not line up, need to flip hub like I saw on YouTube. Can anyone tell me how to slip hub cover off the axle tube? Thanks Please Help
Welcome to Trike Talk and your first post,
Read here, is this what you are trying to do?
After you separate the hub, mark on the axle where the set screw is on the hub. Remove the set screw, have a helper hold the axle and tire hub upright with a board between the axle end and the floor. Using a 2X4 and good sized hammer and drive the hub down and off the axle housing. This will take a while, it is on there very tight. When you have both apart, switch hubs, making. Sure you line up the set screw hole to the mark you made on the axle. Turn the assembly up side down, now lay the 2X4 a cross the center of large hub opening and drive it back on. This will go on much easier. Move the 2X4 around the hub as you do this to get it to go on straight. If you lined up the set screw hole with your mark, the set screw will go back in where it belongs
Ronnie ..........Welcome To trike-Talk.............:wave4::wave4:..
Geezer72
