***DK Custom Products Thunder Torques Inserts***
2021 Freewheeler. We pulled the baffles out of the stock mufflers and installed the W258 Thunder Torque Inserts. We left the packing in the pipes.
1. The engine light came on during the first ride. I'd be interested in anyone's thoughts on this as I wouldn't have thought that pulling the baffles would have changed the air/fuel ratio drastically enough to cause the engine light to come on.
2. And, the inserts are not centered in the mufflers. Is this a problem?
TIA
Have you checked for the diagnostic code that set the engine light?
TIA
Not being centered is not an issue.
Are you running the OEM air cleaner? OEM tune?
We will be having a 2021 on a dyno with a sniffer in a couple of weeks and will have a lot of info regarding OEM AFR and what can be changed out (air cleaner, exhaust) and how that effects the OEM AFR.
Yes, it would be helpful to know what codes triggered the Check Engine Light.
HLG
