2 post lift
Think Jack would know ?
Nope, I duno what cg is
Is cg center of gravity?
I do know 2 post electric car lifts tho. It will be tricky to get it racked on the lift without making a jig to fit the frame rails for sure, being careful around the oil pan
I have racked a lot of strange frame configurations over the years but not a H D Trike yet
Hi Eric, :welcome:to Trike Talk
Does cg = center of gravity?
If it does, you will find the balance point should be about center of the derby cover
You will need to fashion some lift blocks to rack it on your lift. Be careful of the oil pan between the frame rails
Being my front lift arms are shorter than the rears , I back it up . Made a square box of 2x8’s and 3/4 plywood .
However it was very heavy to move , dangerous, and just not worth the aggravation. The wheels did not hang .
I now use a Atlas 1500lb motorcycle/ATV lift . I can sit on my roller stool and do what I need to .
The post lift idea was given up . Just wasn’t to be , for me . Be safe !
