Air Bag Compressor
Here's a list of parts I used and where I got them. The compressor, pressure switch and switches came from Amazon and the SS air line came from Summit Racing because I couldn't find it on Amazon.
[h=1]Viair 92C Compressor Kit with check valve[/h]
[h=1]LEFOO LF20 Extended Duty Pressure Switch 10psi±2psi Adjustable High Pressure Switch Oil Pressure Switch Vacuum Pressure Switch[/h] I got 2 of these so both switches would match.
[h=1]KEING Momentary Waterproof Rocker Switch Toggle - ON/OFF/ON Blue LED Light - 12V 20Amp 24V 10Amp, 7 Pin For Automotive Cars Vehicles Marine Boats Trucks Trailers 4x4 Caravans RVs SUV ATV UTV & More[/h]
[h=1]Viair Corporation 92803 - VIAIR Braided Stainless Steel Leader Hoses[/h]
Hello
I just got done dealing with cruise problem. there is a test where you can see what is wrong. with a selection series on the cruise buttons press on then within certain time press another button. don't remember series. Do your brake lights work, does horn work. i am thinking clockspring
Dragon
Just for info, it was the module. It was full or rust. Luckily, I had a spare one from the last time I had a problem. That time cleaning and lubing it made it work so I kept one I purchased. Didn't work with this one.
Rick, is the module the unit that sits on the right side of the engine at the front with a cable attached? Thanks.
That's it. For some reason I'm not able to send pictures from my phone to the computer. If you need pictures of it, I can try again later when I get home from work. Rick
Rick
I believe the power comes from the power distribution box relay number 9 ignition switch 40a
Dragon
Hello
did richard ever get back to you. it sure would be nice to have a schematic of this system as you cannot look it up in ranger wiring diagram:p. i went back and looked in our forum to see if mt ever answered any of the wiring problems with compressor. it doesn't look like anyone got their questions answered:confused:. i am having compressor and wiring problems now again.
Thanx
Dragon
I have a question should the purple wire to the switch have voltage or only when you press the switch on the dash. also i asked this before if anyone has changed the transducer out.
Thanx
Dragon
edumou
