EFX Floorboard, Left Side
Jun 22, 2017
33
34
Spokane, WA
Chuck
Greetings everyone.
I've got a small problem and I'm hoping there is some information out there. On my ride, I had the Heal/Toe shifter and the support bar for the Main Support was an "L" shaped one to bolt up to the underside of the shifter. Well, I've removed that and gone back to the factory configuration and I had to buy the new bracket. I realized that the support bracket will not fit and in looking at the exploded parts I can see why. So, I'm wondering if there is any one out there that may have the "Bracket, Sujpport, LH Wing EFX" part number S002145 or maybe someone could trace it out and email it. I can get one made up if I have the pattern to work with.
Thanks in advance guys... Ride safe out there...
Chuck
Greetings everyone.
Chuck
Chuck....Try GoldwingDocs.......How to install the gl 1500 shifter brace...
Long story short
Greetings everyone.
Chuck
Chuck,
I only used that bracket in one or two of the WING EFX kits I installed.
Overengineering CAD people leading to double cost of basic components was the road-to-failure for Lehman.
Anyways, I have a solution ... possibly at least for the left side.
The photo was from the original Monarch II WING EFX kit and shows the bracket I am familiar with.
Different part number ... and I won't go into that ... but the main parts are the same.
The picture is of the right side bracket, B/C I didn't have a left side one to show.
Originally Lehman used a bracket attached to the foot peg pivot mount. Very simple KISS and worked for 10 years for me. Then they went on the CAD warpath !
Your board has slots to allow shifting of both the board and the attaching hardware.
Use a plain strap and bend to suit and remove the clevis pin for the pedal pivot and substitute with a bolt.
You can drop it and attach to the original mounting spot. A lot of work went into this explanation ..... you owe me !!:Joker3:
EFX
Jim:
Once again you have come through. Sometimes I tend to overthink things. This idea is superb. Yes, KISS is the best way to go. You just made my day. Thank you sir and yes, I do owe you. Thank you my friend!!!
Chuck
Chuck,
Geezer72
