How much trail?
Feb 1, 2021
7
12
LEOMA
I've read and read unsuccessfully trying to determine how much trail is needed for a (rear eng VW) trike. I've read that as little as 2 inches is correct. Is less trail required for a trike (any) than for a two-wheeler? If so why?
I have access to a good rake and trail calculator and know how to adjust frame rake, offset, triple tree rake, etc to change the trail but I just don't know what trail I should be adjusting for.
Any amount of trail is ridable as long as it is trail and not lead. It may be quite difficult to ride and you certainly would not enjoy it. Being a rear engine the front should be light and you can get away with larger trail. It will go down the highway fine, but the head will shake on deceleration, it will be stiff to steer on the curvy roads, and it will be a bear to wrestle backing up
Two inches is considered the "safe" number. But much depends on the rest of the trike, wheel diameter, fork type, pivot height.. My drop pivot linked shocker front on mine is well under 1 inch trail. The Sugar Bear front ends are ZERO trail.
Motorcycles in general are around 4 inch trail. Motorcycles are more because they lean and a trike does not. A trikes geometry is more akin to a car than a motorcycle.
Shoot for the two inch (if you have normal size wheel,) and if you miss by a little either way you will still be good.
:Santa::Santa::Santa:
Almostagamer
