Rear Suspension Goldwing Champion
Feb 24, 2021
1
3
Pleasanton
Howdy,
I have a 2006 Goldwing Trike w/champion kit. I have had it for 10 years and suddenly I have lost all suspension on the rear. I have absolutely no rear suspension, any little dip or bump in the road and I am scraping the exhaust pipes, I can't go over any speed bumps without nearly high centering the trike.
Is it possible I have a broken torsion bar?
Doug, Welcome to Trike Talk from West Virginia.:wave4:
It sounds like a good inspection is needed. If it is a straight axle model, it should be easily spotted.
If it does have IRS, a sway-bar could seize up and stop moving and allowing the suspension to be active.
The sway bar can be diagnosed by disconnecting each end at the lower a-frames.:Shrug:
rear suspension
I dont believe champion uses torsion bar springs . they use 2 coil over shocks and one central shock, where the original GL shock went.. Take a look under there, to see whats going on.
Im sure more knowledgeable folks will come along with other suggestions.
Rick.
Rick.
Rick, Welcome to Trike Talk from West Virginia.:wave4:
Glad you finally chimed in too.:Shrug:
You describe the Champion straight axle for the GL1500 and the GL1800.
Champion uses coil-overs for their suspensions, 3 on the GL1500 and 2 (axle mounted) on the GL1800 with a straight axle along with the OEM mounted coil-over..
The IRS suspension also uses 2 coil-overs and a sway-bar and eliminates the OEM coil-over.
