Rogue1
400+ Posts
I purchased a 22 piece brake caliper tool to Push the puck back into the caliper. It does not work on my rear calipers. Is there a special manufacturer that makes one that will work on these calipers?
I understand how to put the brakes go on. My concern is the caliper tool I have does not work with these calipers. It's an automotive caliper tool and these calipers appear to be too small for the unit to work. Unit does not fit inside the caliper. And All the discs that come with the tool do not fit the puck like they should.
THE TOOL DOES NOT FIT INSIDE THE CALIPER. Got nothing to do with the emergency brake being on
Jack, do you happen to know the size of the disc that is used on these pucks? 19 Tri Glide. I have 18 discs in my kit and none of them fit the puck the way I think they should fit. None of them fit flush. Only two are even close and have the right size pins
How about a small C-clamp? I've used them on many applications.
Excuse me for trying to help!
I have two inch and a quarter adapters that are the size of the puck but only one has pins that are real close to fitting. The adapter will fit on the puck but the pins don't line up exactly like they should. I'm not happy with the way it sits on the puck
Somebody on here gave me the suggestion of using a pair of needle-nose pliers. It worked great.
