Mighty Mites Help
nucseal
1000+ Posts
Staff member
Gold Member
Jan 16, 2012
1,149
1,413
San Antonio, TX
Pat
Well traded the 16 in for 20 Tri Glide. Want to re-install my Mighty Mites. Bought the 3 pin adapter required for the M8. But for the life of me I can't find where the adapter plugs into on the 20 Tri Glide. I have looked under the left and right covers and didn't find anything that matches to the 3 pin adapter. Can someone please help! Thank you
Its on the right side behind the down frame tube in front of the ABS unit. It has a dummy plug in it. That is where I found it on my 2019.
It's in front of the battery box on the 2020s, or I should say thats where I found one on a 2020 Road Glide I converted. I didnt look in the right side cover....The 2020 TriGlides may be different.
  • Thread starter
  • Staff
  • #9
It's located on the right side under the ABS unit.
Might be tucked in just in front of the battery Pat.
You have to dig around for it, I think mine was under the ABS unit and behind some other plugs.
Thanks Gentlemen appreciate the help! Found it tucked behind the down tube once I removed the seat. Now to get work changing out this horn isolator, always a pain in the a$$.
I found it easier if I remove the 2 bolts that hold the horn bracket to the heads and remove the bracket. That way I can put the bracket in a vice and then work on removing the isolater.
