• It appears that you have unread Personal Messages - Please check your inbox!
quarantined
Dragon
250+ Posts
Dec 28, 2010
294
82
Oly, WA
Chuck
Good morning
Well the beast has a case of elec covid bug.
dash lights flicker
psi and volt meter read 000 or 666 888 on nothing at all
cruise control quit working, installed new switches still no cruise
brake lights quit working, probably why cruise doesn't work
had to have a new heart, battery.
and to top it off it has a parasite drain:confused:.
beast has appointment with doc multi this afternoon
Dragon
(Bug)
Good morning
Well the beast got operated on over the weekend new brake light switch, old wiring had 1 strand connecting the power to the switch, and another had broken completely. Got that all taken care of the air pressure and volt meter came to life and are almost working correctly, brake lights work but still no cruise. air pressure goes up to 7psi to start, i can dump the air but cannot add air to system. I found that the brake side motor that controls the pedals does not work or is jammed. does anyone know how to take these apart and service them.
Thanx
Dragon
Good morning
Thanx
Dragon
The air pump system has a rubber plug on the bottom that you can pull out and use an allen wrench to adjust your start up pressure. I set mine at 20 psi for every day riding and bumped it up to 25 when I was travelling with my luggage rack. Tomg
Good morning
Thanx
Dragon
My brake and gas pedals get stuck sometimes. I lube them up and work them a few times and then they're goo to go for a while.
I had problems with my air pump switch not working to pump up the system. I cycled the switch several times and it started working. Rick
stoney
