Trailer Project for Lucy
TonkaDriver
450+ Posts
Feb 26, 2018
490
853
Bagdad, AZ
Kurt
About 6 weeks ahead of Kerrville I ordered a trailer. Then COVID hit and Kerrville was not going to happen. I had already paid a deposit for the trailer and I will use it eventually. The trailer company got shut down in March. They fired back up May 8th and I was given a delivery date a week later since it was almost done at shutdown. Sally and I headed for Phoenix to pick it up only to receive a call on the way that they built it wrong. Since I wasn't in a hurry for it there is time. They took $500 off for the trouble. They built a single axle, I ordered a tandem axle trailer.
I finally picked it up Thursday. It will live behind our 5th wheel a good bit of the time and since I would not be able to see if I had a flat I wanted an extra set of tires on it.
The first part of the project was to do the floor, mount the chock, and remount the tiedown rings.
I chose an a peel and stick vinyl tile.
It is pretty tight between the cables so I got a couple of pool noodles (not pictured).
This seemed like my best option for tying down the front. I didn't see any place to put any tension on the ratchet straps so this seems to work.
Next on the list is wood trim for the floor along the side. Metal edge for the rear and cabinets for the front.
More Later.
Kurt
Looking good Kurt!
Hoping to see it in person this September!!!
You will. I am headed out this Thursday to scout campsites for the eastern AZ trip. It will be a fun ride for 3 days. I just scheduled vacation for Maggie valley so I will be coming through your neck of the woods then.
Kurt
More Later.
Kurt
Just a heads up.....I strapped my front wheel on my 11 Tri like that...And the strap abraded/scarred the wheel....The next time i had to strap the wheel i put a soft towel between the rim and the strap so it wouldn't happen again...
I usually run the straps around the fork tubes just above the bolts that hold the fender on each side.
Work great!
Bob
Kurt
Hi Kurt when your're down this way be sure to let me know. I'm only about 40 miles from Kevin and would like to meet up with you when you visit Kevin.
Jerry
Kurt, what is the engine in your truck, I assume that is what you will tow with. Here in South Africa we have smaller engines than in the US so my interest is because you are going to tow your trailer behind your 5th wheeler, quite a load.
We visited my son in Connecticut recently and I was delighted to see the trucks on the road, one guy pulled up next to us whilst we having an ice cream, he pulled in quietly but just before shutting down the engine he hit the throttle, lovely noise, turned out to be a 6.8 diesel, unheard of here except in a semi.
My truck is a 2011 F450. It is a beast and has a 6.7 liter. I tow my boat behind the camper quite often and it handles it well.
Kurt
Kurt
Very cool, enjoy you scouting trip! Looking forward to our time in AZ.
When are you headed out to Maggie Valley?
Good point. I also use towels between the straps/soft tie loops and the metal when securing.
I am going to the Maggie Valley Gathering. Making my reservations in the morning. Probably check in on Monday the 7th and check out on the 11th of September.
I am really going to enjoy my scout trip. I will be posting some video to my channel late next week and photos and a mini ride report here starting tomorrow night I hope.
Kurt
More Later.
Kurt
That is a good trailer and I like how you did your inside, pretty cool.
All for now Trampas
Kurt
I was just telling Mary, a few minutes ago, the Kurt is in his first day of a 3 day scouting trip today.
Have fun & be safe!
I agree with using towels on the wheel before wrapping your tie down around it. Most wheels have sharp edges or flaws that WILL cause that nylon strap to fail. Better yet, use soft ties around the triple tree and tie down from there..... Jim
For the front I use the soft ties around the fork lowers (at the fender mounting point), and I use towels between the soft ties and the metal.
Did you mean the fork lowers or the triple tree?
I have always used soft ties from the triple tree. Then ratchet straps to the trailer corners forming an A figure. Ratchet the front fork to about 50% compression. Never a problem..... Jim
I have some straps with built in fur padding that I attach around the fender supports on the fork tubes then I ratchet forward pulling into the chock and compressing the shocks a little
More Later.
Kurt
Great Job
Looks real sweet. And you got at deal too...very cool.. good luck with it
Getting Closer
I am thinking I am about halfway there. Installed the face frame and shelf. I had exactly enough floor tile left to do the back splash. Did more of the trim.
Still need to build cabinet doors, finish trim, build the counter top, repaint in a different color and sand/finish trim. I figure two full days of work left.
Kurt
Kurt
It sure is taking shape and it looking really good, can't wait to see pics when done
All for now Trampas
Size
What size is your trailer? In the market for one and trying to determine the size. Thinking at least 7 x 12
Gary Weeks
