A few more shots. The rear brakes are run from the brake pedal through a parking brake cable to the power brake unit in front of the rt. wheel with a lever to operate the PB. Buddy the dog is demonstrating the remote steering. The tube down through the steering head shows the 2 in. of trail. There will be more framework on the side to make it more triangular to the rear wheels. Theter will be triangular wedge shapped alluminum carrier boxes on each side to give it the F 18 look. There will be a "dustbin" fairing around the front wheel.View attachment 85747View attachment 85748View attachment 85749View attachment 85750View attachment 85751
well on your way! hard to tell from the photos.. but it looks like your connecting rods for the steering are not parallel?? im not sure but i think if they are not parallel and
the steering stems are not parallel it will bind... easy enough to check..
Got the gas tank mostly welded up. Had the metal cut and bent at the metal shop. Need filler neck and vent.View attachment 88813
