2017 Trike Fault codes
Have a 2017 Tri Glide. I recently put LED bulbs in the front and rear turn signals. Now getting the following odes that come back each time they are cleared they all relate to the front and rear right and left turn signals: 62141;62146;62151;62156. Do you think it is just because all those are now LED bulbs???
It sounds to me your bulbs and or plug ins to the lights you have are NOT clocked correctly. Recheck all the connections to be sure the contacts are correct and see if the codes come back
Have you also tried this
Custom Dynamics® Technical BulletinTurn Signal Sync on H-D BCM ModelsQuestions? Call us at: 1 (800) 382-1388 M-TH 8:30AM-5:30PM / FR 9:30AM-5:30PM EST07-2016TECHSome Harley-Davidson models equipped with canbus/BCM electrical systems while installing Custom Dynamics® LED turn signals in place of incandescent bulbs, will need to per-form a turn signal sync so that the product will function properly with the system.1.Turn Ignition on, but do not start the bike.2.Turn on 4 way hazards by pressing the hazard button on the controls. Turn Signal Sync Procedure3.Turn the Ignition off letting hazards run. IF the bike has security they will flash 5 or 6 times and then pause. This is normal. They will go back to flashing normal hazard mode.4.Let hazards run 1-2 minutes.5.Turn Ignition back on.6.Turn off hazards.7.Turn Ignition off and then back on.8.Check function of both turn signals.Note: Follow the instruction above. DO NOT press both turn signal switch's at the same time. That is the way the hazards activate on PRECANBUS bikes.
IMO it will be more likely to have the rear lights plugged in wrong, that could cause the front lights to throw codes also. That is where I would check first.
Keep in mind you still may need to synch your lights once you clear the codes. Good Luck and do check back once you solve your problem so others may learn
I did the same thing on my 2017 Freewheeler & in my research I found not all LED bulbs are CAN BUS compatible. You will get a error code when you 1st replace them, but clearing it should take care of the problem. I used a Sylvania bulb in the rear lights, after insuring they were compatible & it worked for me. I used Custom Dynamics inserts in the front turn signals & really like them. They are the kind that have a white circular running light & turn amber while blinking.
Robert I looked up those codes and they do indeed refer to the front and rear turn signals. Hopefully performing the CD procedure will rectify the issue. By the way the first letter of the codes does indeed look like a '6' but is actually a 'b.'
Thanks Jack!
My turn signal dash indicators have been doing the fast flash (like when a bulb is blown) ever since I upgraded to the LED type. I performed the steps Jack spelled out in the Custom Dynamics® Technical Bulletin post. Now they are working just like they are supposed to.
R/
Scott Smith
